Add ability to set default diameter dimensioning
While drawing in Creo, 90% of the time I chose to manually flip the arrows to the outside of a diametrical feature when adding a dimension. Make this a config option so I can make it default.
4 Comments
Dale_Rosema
Matthew Mantelli
You may want to vote on your own idea....
Thanks, Dale
PTCModerator
Emeritus
MTM
There is a option in the drawing dtl file you can set:  default_diam_dim_arrow_state    single, inside or outside
under.. File - Prepare - Drawing Properties - Detail - Options.
I have mine changed to single in the new drawing template.
olivierlp
Community Manager
Status changed to: Archived
