Actually it is not possible to activate in the same time "Auto Cutline" and "Tool center curve"
This would be very useful to machine closed pocket to:
- start at the center of the pockect using the point
- avoid retract on the contour of the pocket thanks to the "tool center curve"
Actually the solution is not to select "Auto cutline " and to create a projected curve instead which is more work to do
