Would be great to be able to add an 'Edit Internal Sketch' icon into the mini-toolbar.
Then you could edit internal sketch of a feature in two clicks.
LMB select geometry > LMB Edit Internal Sketch (in mini-tool bar).
This would be better than four clicks.
LMB select geometry > LMB Edit Definition > RMB+Hold > LMB Edit Internal Sketch
