Add and enable diametral tolerance zone by default - GD&T
Add a checkbox to options menu, enabled by default.
Checkbox should put symbol to Feature Control Frame, before tolerance value, symbol we forget too many times - to mark diametral tolerance zone for at least all Position and Orientation callouts.
And yes, because it doesn't apply always circular, user will remove it manually. (Until AI will take care of this)
ASME and ISO GPS, both please.
I've searched for similar idea and I'm sorry if I missed it.
#GDT #ISO #ASME
2 Comments
achirila
Moderator
Status changed to: Clarification Needed
Hi @Bohrer and welcome to the PTC Community!
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Here are a few examples of well documented ideas:
Improve/fix the sheetmetal mirror feature - PTC Community
[Eztol] Rename action not synchronous in Eztol - PTC Community
Always enable ability to 'Add View Label' in a dra... - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
achirila
Moderator
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
