It is general practice to create projected view and adding cross sections.
But some times, designer/draftsman forgets to add arrows to its relevant view.
It can be avoided by providing solution by PTC, which enable user to pick its relevant view as mandatory step to add section arrows, immediately after adding section, like detailed-view method which allows user to pick a view.
I face such issues while checking some of printed drawings and difficult to locate it relevant section because arrow line not added on respective view.
