When defining especially customized stamps with dedicated geometry the identification within the selection table becomes complicated
Sha-define-shop-table gives not much more opportunity than adding another text column with supporting comments.
Proposal would be here to have the capability to a an image (thumbnail) per tool to make proper selection easier
