When I need to edit the thickness and color of the printing lines of the geometry, I have to change the Pen Table file because there is no button or menu in the Print tab or in the Settings that allows me to change directly these options.
I know I can create a lot of Printing Configuration Files (.pcf) each of them addressing a different Pen Table, but this has to be done manually and it is not so easy for the end user.
It would be better to manage these options with dedicated buttons in the Print tab, with a default that could be set via Pen Table.
For example, Autocad provides a menu where you can choose the thickness e and a button to define the color:
