Similar to the drawing module, which has:
Config option: pro_dtl_setup_dir
ModelCheck check: STD_DTL_SETUP
There does not seem to be any administrative control over a PART or ASSEMBLY detail options, which can be found in Model Properties. Please think about implementing similar control over these detail options as well.
Thank you!
