Add config.pro option to set DXF export to all sheets as paper space
Currently when exporting DXFs you need to edit the export environment for dxf with every launch. Otherwise it defaults to Current sheet as model space. I realize a mapkey could work, but I would rather have it as a config option.
When All sheets as paper space is selected the dxf exports all sheets to a single file. This is my preferred default.
4 Comments
Topaz II
You may want to vote on your own idea....
Participant
Hi ! I just found your post, and I would require the same...
I would like to export to DWG a lot of multi-sheets DRW, using "Distributed Pro/BATCH" (task done in background, without opening Pro-E/Creo interface)
I need to have all sheets as paper space, however it would require a config.pro option to load in DPB prior to executing the conversion task.
(as DBP doesn't have any of the Pro-E/Creo GUI to set options)
I am using Creo Pro/Elements 5.0.
Community Manager
