Add curve entities merge functionality in IDD
Actualy, it is not possible to merge 3D curves entities from an import with IDD.
http://support.ptc.com/cs/help/creo_hc/creo20_hc/index.jspx?id=To_Merge_Two_Homogeneous_Curves&actio...
The only workaround is to use old feature # Curve from file..... with old UI !
And in this case, interface file must be IGES !
It would be great to have same functionnalities as # Curve from file, in IDD to merge curves imported from IGS,STEP,DXF...
Curve from file is not in the ribbon and propose an old UI with Proe menus.....
1 Comment
olivierlp
Community Manager
Status changed to: Archived
