The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add dynamic note outline shapes from Creo View Lite to Creo Parametric plus more
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Automotive, designer/CAD specialist, auto OEMs
2. What version of Creo Parametric are you currently running?
7.0.3.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Outline of text in drawing detail mode does not have built in dynamic feature.
Workarounds:
Manually draw shape every time I need one, inconsistent.
Make a symbol with editable text inside but is very limited as its not dynamic enough to resize with amount of text.
4. What is the use case for your organization?
Inspection information that is not a dimension needs to be in rounded rectangle
Multiple line box text in one big box not each line boxed
Symbol use to note FMEA level
5. What business value would your suggestion represent for your organization?
Time and consistency. Right now some people do workarounds this way and that. The look in inconsistent.
There are threads on threads about wanting text box outline options. This already exists in another CREO product.
One idea that already exists is for multiline text to be in one box... This idea includes that but goes much farther. https://community.ptc.com/t5/Creo-Parametric-Ideas/Create-a-box-around-text-annotation-in-Drawing-mode/idi-p/468138
Another idea nearly identical but was marked as duplicate with above... Which it was not. Only difference here is I am showing a similar feature already exists in other CREO products. https://community.ptc.com/t5/Creo-Parametric-Ideas/Improve-quot-Box-quot-Text-Style/idi-p/468105
1 Comment
olivierlp
Community Manager
Thank you for your idea, @BG_9869104. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
