Add extra balloons in new view with parts blanked using reps
I have assembly drawing and created a table to show balloons . I have then created additional views of the assembly but used reps to bank out some of the parts, I have now tried to create balloons in these new views using the master table but it will not let me do this stating
invalid view for showing BOM Balloons for the region
Why will it not let me create the balloon as all the views are using the same master assembly in the drawing?
...This does meet our needs as clearing the table removes all the existing balloons and even if we removed the table all together and created a new table to the rep view you then cannot use this table to create balloons in the other views. Therefore the only alternative is that you have to create additional tables for each view that uses its own distinct rep. Alternatively you do not use reps in the drawing only the mater assembly and then blank out the parts in each view as required.
2 Comments
slapha
olivierlp
Community Manager
Status changed to: Archived
