The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add filters to Creo Ideas.
We should have to ability to filter and sort Creo Ideas by date and resolution.  Someone sead that some of these ideas are under consideration.  Where can I go to see the ones that are under consideration?  I'd like to vote up or down on the consideration and give my opinion on ideas that are important to me.
Some of the older ideas or the ones that do not affect my current software I do not want to see.  Why even have Wildfire 4.0 ideas?  Are they really going to add or remove functionality in a patch.  They should be removed and given a reason for removal.
Old ideas that are rejected should still be searchable so that we know why the ideas are rejected and won't be implemented in any new versions.
2 Comments
TomU
There are two issues here.  The first issue, how you interact with ideas on the community, should be solvable by the PTC community team (@Jaime_Lee@lindafrembes@MarianaCogan) and the Lithium Team.  The second issue, someone inside PTC managing these ideas is a much larger problem and involves multiple levels of product management.  Toby was trying to improve this but unfortunately no one inside PTC seems to want to take ownership of the ideas, respond in a timely fashion, keep their statuses up to date, and delete the garbage.  The last time I ran the metrics (about a year ago) only 1% of Creo ideas and about 3% of Windchill ideas had ever been responded to by someone at PTC.  This is frustrating since the ideas are the only supported method available to affect change.  (Technically working groups could be used to skip around the ideas all together, but that's a different discussion.)  Much of this has all been hashed through before on Does-PTC-ever-read-these.  After five years with no real improvement, it's hard to remain optimistic.  Hopefully Jamie will have more success than Toby did.
olivierlp
Community Manager
Status changed to: Archived
