Add function to show references of a created dimension.
Would like a function that will show me the references for a created dimension. Currently in Creo 4.0 M09 there is no way to do this. You can edit the attachments of the dimension, but this does not show the existing references.
User created a dimension, another user modified the design and was complaining about dimension not updating or show as out of date. When looking at the dimension it appeared he was correct, but in fact the first user created the dimension wrong. There was no way of finding references for created dimension. Case was created with PTC, which resulted in waste of tech support time.
Please consider adding this functionality.
Wayne Schrock
1 Comment
olivierlp
Community Manager
Status changed to: Archived
