1. Environment: consumer goods with mainly injection moulded plastic parts
2. What version of Creo Parametric: 7.0.8.0
3. Problem to be solved
Add Add Arrows and Section Name in 2D drawing for views based on a Zone cross section (3D cross section).
Question also raised in:
Proposed resolution: To request this functionality, refer to Product Ideas @ PTC Community --> hence this product idea
4. What is the use case for your organization?
We would like to create shaded cross section view on 2d drawings to be able to communicate additional manufacturing information by using different colours to represent e.g. surface finishes requirements and/or interface areas.
5. What business value would your suggestion represent for your organization?
Workflow improvement while respecting labelling according ISO standards.
