With a big push to convert to a metric design it would be nice to know what components are still at imperial units. Having the capability to show this in a table for the designers to reference would be a great asset.
This is actually ALREADY POSSIBLE. There's a switch that needs to be turned "on" in all your parts and assemblies. However, once it's on, you can pull up the units for each object in your BOM. Also, by turning this switch on inside your start part and start assembly, all future models will automatically have this switch on... so it won't need to be manually activated.
While PTC could certainly take the extra step of giving us a new model parameter to display the units... there defintely *IS* a way to do this right now. If you'd like more details, send me a message or start a new thread in the Creo discussion group and I'll explain further.
