With NX you have the ability to set global options for PMI properties, such as font, color, etc. Here is an example for default font and color of general note text:
I have not found a similar option in Creo. Most PMI settings seem to be model-specific, although there are a few basic global options available in recipe files. Specifically we would like the following to be supported as global options:
