Add hose(flexible pipe) functionality in Piping module
Add hose(flexible pipe) functionality in Piping module. Only rigid pipe is not enough.
9 Comments
gzhou-2
2-Guest
Information from PTC that flexible hose will be added into Creo 4.0
ptc-4226637
1-Newbie
Creo 3.0 is not released at all, now plan for Creo 4.0 is out.
DomenicLaritz
Here I must link my idea - it also has to do with flexible pipes:
Improve spec. driven piping for enhanced handling of hoses (flexible pipes)
ljin-2
2-Guest
info from PTC, this project is cancelled from creo 4.0,
StephenW
23-Emerald I
I'm not sure what I am missing on this post but flexible piping has been available for years in the piping module. If you create your linestock as flexible or add flexible as an option. Then, when routing your hose, you go to environment and set your line shape to flexible (fixed or set length) or straight (for rigid pipe).
lbai
Real flexible piping means one same hose with a specific length, which can be re-used in different location path or even assembled into other assembly files too.
StephenW
23-Emerald I
Ok, now it makes sense. This is not clear in the original post.
danderson
11-Garnet
And moves with components in a mechanism assembly or assembly with motion.
PTCModerator
Emeritus
