DWG 3D - data files are not loaded in Elemets Direct Modeling.
Creo 3.0 has this capability and the user can select to load the 3d assembly (wire frame object) or the 2d drawing (ortogonal views of the 3d objects) contained in the DWG 3D files.
This functionality can be usefull for the customers that need to work with autocad 3D files.
Franco Mazzucchelli
