Add locations in Piping (similar to cabling)
It would be awesome to have the "locations" feature in Piping. Locations are currently used to route on Cabling and they make cabling routing extremely easy. but when you are routing a flexible hose on Piping it would be extremely useful to have the feature of adding a "location" or even better an "offset location" without having to care about the order of the pipe segment in the model tree.  You need a location, you add the location, done. You need to make changes, you edit definition of the location and place it on the correct position and done.
