Add offset coordinate system points by clicking from model
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Telecommunication, Designer. Mechanics.
2. What version of Creo Parametric are you currently running?
8.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
It should be possible to pick points from model to coordinate system table or relate/connect them to 3D.
4. What is the use case for your organization?
This is for general usage. Also I write scripts to convert coordinates to SMT printer programs.
5. What business value would your suggestion represent for your organization?
This would shorten the points creation time for new products. Number of points to transfer is around 100 pcs per product. Copying later is easy as points can be imported from txt-file to offset coordinate system table.
1 Comment
olivierlp
Community Manager
Thank you @jussikoo for your idea and welcome to the Community. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
