Add one level up, or select parent function
0 Kudos
Add back a function that just selects parent so I can use it in my mapkey. Nobody got time to look at that tree and desipher from the part name which parent they want. We just want to click a part on the screen and keep smashing our 'select parent' mapkey until the appropriate parent is highlighted.
6 Comments
StephenW
23-Emerald II
It's still there, RMB Select parent. (at least in Creo 4, maybe it disappeared in more recent releases?)
I assume you can also record it to a mapkey.
ZaneGE
3-Visitor
I had to customize to get that in my menu, but sure enough, it works. Thanks!!!
HBreton
6-Contributor
For some reason that only works for in in the model tree, not in the graphics area.  "Select Parent" is greyed out when I try to add it to the shortcut menu.  I created a Mapkey with the one in the model tree but it only works there, not when I select a component in the graphics.  I'm using CREO 10,0.
Thanks for any help,
kdirth
20-Turquoise
Have you tried the Select from Parents button?  Select a surface and you can select any level above it.
HBreton
6-Contributor
I've seen the select from parent but I prefer the select parent function.  Easier and quicker for me.
But thanks for the suggestion.
olivierlp
Community Manager
Status changed to: Archived
