Add “open” command from contextual shortcut drawing mode
Please add an "open" command in drawing menu to directly open the model without passing by model tree.
4 Comments
Dale_Rosema
For assemblies would it open the assembly or the particular part it is hovering over?
NicolasBourgeoi1
By default, it would be opening the top assembly.
I don’t know if they is a component selection by "hovering" over.
If you use filters, you could always select the "component".
The general idea is to select and open more directly from drawing mode.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
