Add option to Export Drawing in pdf with custom size (out of the drawing format)
I have text and geometry out of the drawing format, I would like to export my drawing in pdf format but the final pdf is cutted to the drawing format dimensions.
Now I have to print in hpgl and then to convert hpgl in pdf, I don't have a vectorial pdf and I have poor quality.
Case 11905584:
https://www.ptc.com/appserver/cs/view/case.jsp?n=11905584
Article CS19052:
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS19052&lang=en
Spr 2059867:
https://www.ptc.com/appserver/cs/view/spr.jsp?n=2059867&source=sprviewer
6 Comments
Moonstone
I voted down, because Pro/E's behaviour is as I would expect it.
Garnet
I would like an option, not the default behaviour.
Moonstone
That would definitely be something I could live with!
If the text for the idea gets adapted for this, I'll vote up the idea ...
Garnet
"Add option to ..." is ok for you?
Newbie
good idea!
Community Manager
