The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add option to automatically regenerate in session instances after generic regenerates.
Add option to automatically regenerate instances that are in session after generic regenerates. Not all just those that are in session. When other instance are brought into session they regenerate based on the state of the generic that is in session.
If instances are in session and I make changes to the generic the in session instances do NOT update unless I verify through family table or open the instance in a window and regenerate that instance manually. These are extra steps that I would like to eliminate.
By doing this automatically I can switch to a in session drawing or assembly that has instance in it and see the results immediately. This will save time and potentially reduce errors because someone did not realize the instance was NOT regenerated.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
