Add option to exclude DRAWING Construction Points when printing / exporting PDF
In Creo Parametric DRAWINGs: please add the option to exclude Construction Points (drawn within DRAWING mode) during print or PDF export. Adding the option to include/exclude all types of construction geometry from prints/exports should also be considered, if not already available.
I precisely position text by attaching On Item Notes (Annotate>Note>) to pre-located construction points (Drawing>Sketch>Point). Changing note positions exactly is also easier: just translate the attached construction point. Attempting to move notes directly often results in shifting them inadvertently when trying to select the notes. Currently, I have to delete all the points to stop them from appearing in the prints / exports.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
