Add parameters to OVERALL_SIZE to not take in account hidden geometry
At this time, with function OVERALL_SIZE all the geometry include in the model is taken in account in the calculation, even if the geometry is hidden. So it's not possible to exclude construction geometry and that gives wrong result...
The fact to allow user to specify if they want or not hidden geometry could help to have best result.
1 Comment
S_Edgenear
This should be taken into account when calculating Bounding box of a part or assembly, to be able to caculate view scale when using view Refit command, or when projecting views in the 2D drawing environment.
