Add pick and place features into Creo Parametric for standard items, eg circlip grooves,keyways, etc
Add pick and place features into Creo Parametric for features defined by international standards like circlip grooves, keyways, Jic-thread, O-ring grooves etc. Etc,. So implement the parts library of Creo Elements Direct.
This can be done via UDF's and show an example model. Afterwards it should be possible To replace the feature with another instance of that UDF without coming into feature-resolve mode.
4 Comments
mwa
This functionality saves a lot of time searching for the right norms and tolerances when this is implemented in standard Creo Parametric. Tolerances according norm should be in  the features so that they can be shown on drawing or in MBD.
mwa
https://m.youtube.com/watch?v=4f-zNTagwwY
See for example this video at time 20:25: the size of the needed feather key is automaticly selected when picking the diameter of the shaft.
mwa
See also above video at time  25:37 for standards center holes and circlip grooves according to different norms
mwa
Think  also about other standard items which should be pick and place features like:
- center holes
- grind grooves
- O-ring grooves or grooves for other standardised grooves like shaft seals
- splines on shaft accodding different ISO standaards
- shaft knurling
- JIC thread holes and JIC threaded pipe
- Etc.
