New option appeared in Creo 3.0 for Inheritance fonction and geometry copy: "No dependency"
This new option could be dangerous because it breaks totally the dependance with the reference part with no possibility to go back if the user choose it by error.
Its name is too close from the toogled option in Creo 2.0 "dependent" when the user could select or deselect this option to make the fonction dependent or independent
A config option to make this new option hidden would be safer to avoid serious mistakes.
