Add possibility to use taper mill tool in engraving and surface milling step
We have a lot of tool closed from the shape described by taper mill tool mostly use for engraving. But we can not use the taper mill tool type for engraving and surface milling steps. We can only use milling tool which reprsente a big cone instead a a shank diameter (see image below) or defini a solid tool.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
