Add "ModelCHECK" in the report of "Functionality Usage"
Currently ModelCHECK is not available in Performance Advisor's dashboard "Functional Area Usage > Functionality Usage".
Also see PTC's document CS252752.
As we use ModelCHECK quite extensive, having it listed in the list of "Functionality Usage" would be helpful!
4 Comments
SvenR
Aquamarine
Details about MC modes and configurations used would be helpful since it's used on all models if you use the modelcheck gatekeeper with Windchill.
PTCModerator
Topaz I
lwestbrook
Moonstone
Hi
I think this would be a really good thing for Performance Advisor to report. @DomenicLaritz Can you comment on the type of information you would like to see for ModelCHECK?
It's not something that is in plan, but this will help me build out requirements for it.
Luke
lwestbrook
Moonstone
One thing I'll note is that you can see, at least to some extent, ModelCHECK usage in Performance Advisor, but it's a bit buried. If you go to Design Part or Design Assembly, for example, in the Functionality Usage list, you can view the Commands data and scroll down to ModelCHECK Interactive and ModelCHECK Regenerate. Here you can see how many times those buttons have been pressed within the specified timeframe. Here's an example:
