I suggest to add Outlined only / Filled only / Both Outlined and Filled options to TEXT STYLE in Creo Parametric DRAWINGS (Notes, Dimensions, etc), especially when using True Type Fonts.
Fill should also have customizable transparency, color or color gradient and Outline thickness should also customizable.
