Add "change standard" functionality in Creo Illustrate
When a new illustration is created is not possible to change the setted "standard". Then if I need to customize some callout, symbol, explode lines in an old illustration I need to redo it now. It is not acceptable for us.
3 Comments
rkupers
Granite
Another disadvantage of using the Creo Illustrate standards is that the file size can grow considerably. The reason for this is Creo Illustrate copies the whole standard folder into a Creo Illustrate file. If your standard contains many symbols and/or stamps, they are all copied into the Creo Illustrate files. Maybe the local copy is also one of the reasons why it isn't quite easy to change the standard in an illustration.
sdanet
Newbie
I don't understand why this functionnality doesn't exist. It's a big problem for us too
PTCModerator
Community Manager
