It would be awesome to have the "Tape" feature on Piping as it is on Cabling to indicate the location and color of tapes. Tape marks are commonly used in hoses for identification, alignment, mistake proofing or to indicate the position of a clamp or retention. Right now the Cabling module in Creo allows the user to add Tapes in the harness and that Tape location/distance from other components can actually be measured on the drawing and it is even exported in the XML if you use other cabling specific software for print production.
