It would be very useful and save a lot of time to have the ability to use the Fill tool within the IDD environment as is the case with the Boundary Blend.
Currently (Creo Parametric 7) to create a planar surface you need to create it after the Import Feature and then use the Collapse tool to insert it into the Import Feature.
