Add the ability to control a sketched conic arc by its apex and centerline
1. Describe your environment:  Aerospace, Product Development, CAD Admin
2. What version of Creo Parametric are you currently running?  8.0.7.0 and 7.0.5.0
3. (See attached)
4. What is the use case for your organization?  As we work with airfoils and complex curves, this functionality would be potentially widely used.
3 Comments
achirila
Moderator
Status changed to: Clarification Needed
Hi @scarroll-2!
Thank you for publishing your idea.
However, you give the bare minimum of information. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Here are a few examples of well documented ideas:
Improve/fix the sheetmetal mirror feature - PTC Community
[Eztol] Rename action not synchronous in Eztol - PTC Community
Always enable ability to 'Add View Label' in a dra... - PTC Community
Please elaborate within the next two weeks.
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
scarroll-2
3-Visitor
3. Add the ability to control a sketched conic arc by tangencies and/or its apex and centerline, similar to what is currently possible with elliptical sections. As of this post, only endpoints and a Rho value will suffice. (see attachments in original post for further description).
achirila
Moderator
Hi @scarroll-2!
Thank you for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
