When adding geometrical tolerances in a drawing or in a 3d model (MBD), You can face the following situation :
- Your geometrical tolerance is composed of multiple lines (in this example 2 at start) :
- If you need to add a line between existing lines, Creo will not allow you to do it. It automatically add any new line to the last position. With this behavior you will need to change/correct all lines before the last one...
Can you add the possibility to reorder the created lines for geometric tolerances?
Thanks in advance
