The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add the functionality of Creo Direct and Creo Elements Direct into Creo Parametric
0 Kudos
Add the possibility to do Direct Modeling into Creo Parametric with the same functionality as Creo Elements Direct has.
So a designer can choose at conceptual  phase of a project to get quick designs easy to modify/change and If the design is more clear: parametrize this model.
Add also the push and pull functionality of Creo Elements Direct and the parts library.
