A few versions ago the little green triangle "play" button was added to the UI. The addition of the triangle adds many clicks to my day, as well as having to redo many operations because nothing was reminding me to switch an option. I don't believe the green triangle benefits me in any way, but often frustrates me.
For instance creating a copy of a part, but wanting to use Mate Align to position. Preselect a part, right click, Copy, click on the green triangle, mate align...
For instance align a face with offset. Preselect a face, click align in the mini-tool, click the Ref Face, click on the green triangle, enter an offset.
For instance position a part using Mate Align. Preselect a part, click Position in the mini-tool, click on the green triangle, click Mate Align...
For instance pull with draft. Preselect a face, select pull face from mini-tool, click on the green triangle, add Draft Angle...
For instance creating a copy of a part, but not immediately realizing I'll want to change the owner. Preselect a part, click Copy in mini-tool, move the part using the 3D CoPilot, forget to click on the green triangle to change owner since there's no visual reminder, middle click, notice the part isn't in the assy I'd like, scroll through the browser to move it to where I'd like.
