The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Adding/Removing Geometry Points should update in Patterns when the reference pattern is not in Session
Step to reproduce:
1 - Create a reference pattern in a part using an external reference from within an assembly.
2 - Save,  Close everything and erase from session.
3 - Open just the part without any of the references in session.
4 - Edit the first pattern member and add a geometry point.
5 - The Geometry point does NOT propogate through the other pattern members, even through the pattern does regenerate and everything else works.
PTC Support said this is NOT a bug but a feature limitation... so the only way I can get this fixed is posting it here and hoping someone reads it.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
