Adding a GTOL Indicator directly to the dimension.
We would like to add the GTOL Indicator directly do the dimension – without a GTOL itself (the same as on the screenshot from the DIN/ISO norm I have attached to the Case).
2 Comments
sacquarone
20-Turquoise
Note from PTC Technical Support,
Here is below the snapshot from ISO Standard:
This symbol is already available in Creo Parametric 4.0, but can be currently be attached only to a Geometric Tolerance thanks to the Intersection Plane / Symmetry / Indicator as shown below:
Scope of this idea is to give access of same symbol but as part of attachment on dimensions (and not only Geometric Tolerances), according to what ISO standard is documenting.
olivierlp
Community Manager
Status changed to: Archived
