There was a difference between using Creo Parametric to measure the distance between two parts and using CreoView to measure the distance between two parts.
CreoParametric setting seems to be able to set Clearance_traianglulation in the config setting as in CS9461. CreoView doesn't have that setting.
Currently, our company uses Low for the Clearance_traianglulation setting in Cero Parametric, and CreoView doesn't have that feature. The Clearance_traianglulation setting has the same result as NONE.
Also, I would like to add this function to CreoView and add a function that can switch the default to Low and display it, so that the difference between the calculated display results of the two software can be eliminated.
