1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Our organization is active in the field of construction machinery, combustion engines, and hydraulic components. I work in the IT department of the company, and we have a CAD-CAM integration project. We want to use the Model Based Definition on Creo Parametric (drawingless).
2. What version of Creo Parametric are you currently running?
Currently, we use Creo Parametric 7.0.3.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
With the use of MBD, in the combined report MBD1_Site_Map, we have to identify all available combined views. To do this, I used unattached notes and added a hyperlink. In the images, we notice that the attached notes cannot be aligned, nor moved in groups. It would be interesting to be able to align unattached notes with a hyperlink in the 3D model.
4. What is the use case for your organization?
We want to integrate MBD into our construction and manufacturing methodologies.
5. What business value would your suggestion represent for your organization?
CAD-CAM integration, manufacturing and design process improvement
