Alignment of multi line dimension text
0 Kudos
In  Creo 4.0, when placing dimension with 2 or more lines of text, the vertical center of the text is not snapped to the vertical placement. Usually, the center of the "number" (what ever line number it is on) is the "center" of the dimension placement. If you look at the "11.000 REF" it is centered left to right, but the "9.500 REF" is centered on the "9.500", not the center of the "9.500 REF" text space.
1 Comment
Dale_Rosema
Has this been address in any later versions of Creo?
