Please add the ability to add multiple Motion Axis Constraints to Snapshots when defining a snapshot.
It's very time consuming having to select the command "Motion Axis Constraint" then only being allowed to select one motion axis and have to repeat 20 times.
Also Highlight joint Axis on screen when Selected under the Constraints Tab while defining a snap shot.
Don Anderson
