Currently, when a feature is part of a pattern it can no longer be copied and pasted (see the following fig.). It would be nice if the Copy - Paste/Paste Special operation was also present for the features belonging to a pattern.
Copy Command is available
Copy Command is no more available
The same happens in assembly mode if you try to Copy - Paste/Paste Special one component belonging to a pattern (see the following fig.)
