Allow Creo Parametric PRT & ASM default naming scheme to be customizable
When working in Creo Parametric, sometimes the default naming scheme delivred by Creo can be different to the company naming rules. This creates extra work for the designers mainly doing repetitive "Rename" actions in Windchill...
Example 1: in a hydraulic hose, when finalizing the routing with a "solid pipe" feature : the feature gets automatically the pipe name + 0001/0002/0003/etc... :
Example 2 : Skeleton are also created with the assembly name + extra numbers (0001/0002...)
All this behavior is described as work to spec in this PTC article : https://www.ptc.com/en/support/article?n=CS58009&language=en&posno=1&q=digit%20piping&source=search&...
To avoid losing time doing unnecessary renaming in Windchill, the Creo Parametric naming scheme needs to be customizable for each company! (with config option ... or another method) Smiley Happy
Thanks in advance
Related PTC Ticket : CS58009
1 Comment
ICAD_Support
Dear Sir,
can we customize the part name series from prt001,prt002 to any onther and how..
Please help.
