There should be the ability to place limits for flexible items, specifically pre-defined flexible items. This would be similar to placing limits on mechanism movements.
Most commonly we use this in vendor components that have max/min conditions.
Adding limits could also prevent the model from entering an unstable or unrealistic state.
Example: If you use flexibility on the length of a spring there is no way to prevent a 0 height spring, or a spring longer than the max length the spring should be stretched to.
Here's just a sample idea. Though it would need the ability to have no limit set as well.
There are work arounds that others have found (flexible component with limits) but none are strict limits with dialog boxes telling you why you're getting an error and what the range is.
