Currently, in Creo Parametric 2, users have no access to the find tool or the layers in the source window for an external copy geometry. This means if say the axis layer is not shown, you can't search for axes to copy. You have to completely back out of the process, open the source file, turn on the layer in the source file, then restart the command, in order to get to the geometry you need.
PTC, please make the Find tool and Layers available in the source copy geometry window.
