Presently, If the wire data tables in Creo Schematics are in English or Metric units and the Creo Parametric drawing is in the other unit family, HMX says "Mixed Spool Units have been detected and logged. Exiting" then kicks you out of the program.
If someone has models in both types of units, they would need to keep two data tables on hand ans switch between them in order to make schematics.
It makes sense if HMX can convert the needed values to match the spool information to the model.
